2000 suburban steering gear replacement help
Old Oct 11, 2013 | 6:46 PM
2000suburbanjeff's Avatar
Default 2000 suburban steering gear replacement help
ok i have 2000 suburban 1500.i'm replaceing the steering box is there any pointer or tips out there on what to do and dont?also can i remove the pit arm and box at same time?because i'm replacing both.ty
Old Oct 12, 2013 | 7:38 PM
got it done.was no way pull the pitman arm off with puller.had to use fork to knock loose pitman arm.and pull the steering box with pitman arm on.there not enough room use pitman arm puller because metal stuff in the way.
2000suburbanjeff
Nov 17, 2014 8:26 PM
r3333d
Jul 24, 2014 9:16 AM
2000suburbanjeff
Aug 31, 2013 1:28 PM
97Silverado1500
Nov 7, 2012 3:50 PM
313hitman
Nov 1, 2006 2:35 PM
