2000 tahoe replacing interior door handle
Can someone give me any tips on replacing the interior driver side door handle in an old body style 2000 tahoe limted edition. I found another forum (http://www.fullsizechevy.com/forums/...d.php?t=104310) where they had instructions for this with manual windows and locks but they said it would be different with auto windows and locks.I guess I just wanna know if this is really that simple or if I will end up taking off the door panel and not know where to go from there, thanks.
Once you get the door panel off the hard part is over.
[hr] Door Outside Handle Replacement Removal Procedure [ol]Remove the trim panel. Remove the water deflector.
Remove the outside handle rod from the rod clip.
Remove the lock cylinder rod from the rod clip. Apply masking tape across the door handle on the outside of the door to secure the handle while removing the nuts. Remove the outside handle mounting nuts.Remove the rubber cover in order to access the outboard nut. Remove the door-lock cylinder from the outside handle housing. In order to repair a binding lock cylinder.
Remove the handle. [/ol] [hr]
