2000 transmission please help!!!
Old Oct 27, 2012 | 9:11 PM
Endfinger's Avatar
Default 2000 tahoe transmission problems please help!!!
ok so is exactly everything that I did up until the transmission stopped working. so iam a new chevy owner and absolutly love it. I attempted a oil change in doing so i released the transmission fluid and adding oil to the engine. After this i noticed a weird clunk followed by redlining of rpms, car was pulsating followed by abnormal gear changes. after 20 or so miles i relized my mistake and drained out the remaning oil in tranny, added new oil and a lucas treatment to help with slippage and changed filter. after i was done i ended up breaking my cable shifter clips and made a hose clamp hold it in place i test drove all gears worked better than ever. i drove about 30 miles and found some loose gravel and stuffed it to about 3000 rpms for 3 seconds had some wheel hopping then popped out of gear now none of the gears work or my 4x4. i became stranded. any idea on what happened please and thanks in advance!!!!!
2000 chevy tahoe new body z71 4x4 171xxx. tranny replaced 150xxx .so they said
Old Oct 28, 2012 | 10:39 AM
bdburb's Avatar
Check your linkage again to make sure it's adjusted right. If that's ok sounds like your transmission is toast and needs a rebuild.
Old Oct 29, 2012 | 12:18 PM
Endfinger's Avatar
So an update on the situation I decided to give it another go I put it in every gear and with a little more gas I was able to move the car but it didn't shift and it smelled
vet67coupe
May 10, 2014 11:33 PM
beezey
Nov 24, 2011 4:01 PM
