2001 Chevy Suburban Radio, A/C Control, Gear Shifter Display Problem
Old Jun 30, 2018 | 11:28 AM
legochris's Avatar
Default 2001 Chevy Suburban Radio, A/C Control, Gear Shifter Display Problem
I took off my dash to install a hands-free calling device to my CD/radio module. During the course of that install, I must have made a mistake somewhere, as when I turned on the car after attempting the install, the radio module appeared to have no power. I then realized the gear shifter and odometer display was not turning on with the car either. I am able to change gears, but the display doesn't seem to turn on to tell me what I am in. Additionally, the AC control module doesn't seem to turn on the fans when I turn the *****.
I have tested some of the fuses that I thought would be relevant (IGN 0, ILLUM, RDO 1, HVAC 1, HTR A/C) and they were all fine. Any ideas what I could have touched that would cause all of these to malfunction?
Old Jun 30, 2018 | 4:03 PM
subfan597's Avatar
Does the fan blow if you have the heat on? If not, it appears that you somehow affected the blower motor resistor located under the glove box, or I should say the power supply to it. I would suggest redoing your work; it's probably something as simple as inadvertently disconnecting something or failing to reconnect something...maybe both. The fan and shifter display may be a result of the first example, while the radio a result of the second.
Old Jun 30, 2018 | 6:08 PM
legochris's Avatar
It turned out to be a fuse after all. I had checked in the fuse box to the side of the instrument panel, but it turned out that there is a RADIO fuse in the fuse box under the hood that controls the power to the instrument panel, HVAC system, and the radio unit.
Old Jul 1, 2018 | 11:01 AM
subfan597's Avatar
Whoda thunk? But good to know; would never had expected that that combo would be the result of one fuse.
