2001 Suburban 2500 auto ride shocks
Old May 21, 2015 | 12:02 PM
denm613's Avatar
Default 2001 Suburban 2500 auto ride shocks
My Suburban has auto ride shocks, and if I replace them with the same shocks it will be expensive, anyone have a suggestion.
Thanks Dennis
Old May 22, 2015 | 12:47 PM
Scotiapilot's Avatar
IMO not worth it. Replace with regular shocks.
Old May 23, 2015 | 6:47 AM
denm613's Avatar
If I replace them with regular shocks, the light on the dash will stay on, how do you get it to go off? Thanks Dennis
Old May 24, 2015 | 12:14 AM
Pull the fuse for the autoride system. Its in the underhood fuse box
Old Oct 9, 2015 | 8:38 AM
denm613's Avatar
Default auto ride
I've looked in the fuse box under the hood and on the side of the dash, I'm not seeing anything marked as auto ride. What is the fuse marked as?
Old Oct 9, 2015 | 11:06 AM
mulmur1's Avatar
The fuse is located under the hood and marked as RTD Autoride (Real Time Damping) image below
Old Oct 10, 2015 | 6:37 AM
denm613's Avatar
Thanks for your help, I'll be pulling that fuse today. I'd taken it to a shop and was quoted a price of around $1700 and I think that's a bit much for four shocks.
Dennis
Old Oct 10, 2015 | 8:16 AM
denm613's Avatar
I've just pulled the RTD fuse, but the message center still says---Service Ride Control, what can I do to get the computer to think there is no Auto Ride option?
Thanks Dennis
Old Oct 10, 2015 | 10:18 PM
mulmur1's Avatar
To remove the error message, you can either have the bcm reprogrammed or add a resistor to fool the system into thinking that the system is still in place. The reprogram is the best solution, but more expensive. It essentially would delete the auto ride system, so that the computer does not think it is installed.
Old Nov 10, 2016 | 4:10 PM
Ian Reilly's Avatar
Disconnect the Negative battery terminal, remove the fuse, reconnect battery.
Just learned that on another site looking to fix the same issue.
Thanks Dennis
Jackson 63
Feb 11, 2015 5:36 PM
stevenheard
Mar 20, 2014 5:58 PM
01burban
Mar 11, 2009 10:00 AM
hunterjo
Jan 30, 2009 2:52 PM
