2001 suburban,changing catalytic converer
Old Jan 31, 2012 | 2:12 PM
daytooday's Avatar
Default 2001 suburban,changing catalytic converer
I am trying to change the catalytic converter and I can;'t get the nuts loose. The two at the rear came lose with a cheater bar. I now have broken out the pneumatic impact wrench and the others still want come lose. Before I try to come up with a long cheater bar, does anyone have nay ideas.
Hopefully thanks
In advance
Old Jan 31, 2012 | 5:43 PM
EinST's Avatar
Try some PB Blaster and give it an hour to work itself in.
Old Feb 1, 2012 | 8:45 AM
hicksvilleshick's Avatar
X2. if that fails, about the only other option is to heat them up...
:chug:
Old Feb 1, 2012 | 9:24 PM
MDTAHOE's Avatar
Professional Mechanic
If you get a longer "cheater bar" they will probably break off. Try penetrating oil as stated above (PB blaster is one of the best). After that you will need a torch.
Old Feb 3, 2012 | 11:14 AM
ShaneDMac's Avatar
Take it out, hollow the cat, then put it back it. Instant performance upgrade! Just not so smog legal.
Old Feb 3, 2012 | 12:18 PM
SabrToothSqrl's Avatar
Default gut the cat
I believe most modern cars will also throw a check engine light if you 'gut the cat'.
Old Feb 3, 2012 | 7:40 PM
Not to mention running like crap cuz the ECM can't make the fuel/air ratio right.
01silverado231
Nov 18, 2014 4:37 PM
2rainbow
Jul 20, 2014 7:52 AM
Delray1969
Jan 19, 2013 10:57 AM
aboyaser
Nov 20, 2012 9:04 AM
dsfboo
Nov 29, 2009 5:42 PM
