2001 Suburban intermittent engine hesitation
Old Apr 7, 2019 | 7:52 PM
gowansg's Avatar
Thumbs down 2001 Suburban intermittent engine hesitation
When the engine hesitates;(esp. when cold) the strange thing is that when it does hiccup, each time the tempature gauge shows it by pegging temporarly to hot. I am positive the engine is not running hot. When running properly the temp. gauge shows normal. OK experts, what's is the connection ?
The engine only does this 5-10% of the time but keeps running. 220k miles.
Old Apr 7, 2019 | 8:06 PM
oilcanhenry's Avatar
Put a thermometer in the radiator, to check that your gauge and sensors are reading correctly. That would be the first step in diagnosing in order to solve your issue, IMO.
Old Apr 8, 2019 | 5:30 AM
gowansg's Avatar
It isn't overheating. It can do this 10 seconds after starting.
Old Apr 8, 2019 | 12:44 PM
Irish_alley's Avatar
I'm here for the party
a poor connection, the hiccup prob temporary loosens the connection causing the gauge to peg till the engine goes back into place. the hiccup itself could be from the bad connection
Old Apr 8, 2019 | 7:05 PM
gowansg's Avatar
Connection. What connection. A loose plug wire. Surely a loose connection on the temperature gauge isn't going to make the engine falter, is it.
Thanks
Old Apr 8, 2019 | 9:06 PM
loose ground wire
