2001 Suburban Starting issue
Old Feb 8, 2010 | 8:46 PM
knogues's Avatar
Default 2001 Suburban Starting issue
I have a 2001 <NOBR id=itxt_nobr_0_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">suburban.. I’m having intermittent problems with it starting.</NOBR>
<NOBR style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen"> Sometimes it has a fast repetitive series of clicks when holding the key in the start position and won’t start. Sometimes it does start just fine. The battery was tested and it’s supposedly ok, the alternator is ok, and the bolts to the battery cable at the battery have been replaced. Any ideas?fficeffice" /><O></O>
</NOBR>
Old Feb 8, 2010 | 8:50 PM
maxxman04's Avatar
generally that clicking is the starter solenoid. either it needs to be looked at, the cables to it checked, or it's bad. the solenoid is attached to the starter. it's the part that the battery cable, as well as a few other smaller wires, attach to. check those wires, and make sure starter bolts are tight.
Old Feb 10, 2010 | 8:14 AM
knogues's Avatar
Could the solenoid cause a power loss? After driving it yesterday, when I turned the car off, for a couple of seconds I noticed a power loss in the interior (dimmer lights, radio, etc.) It's like something is shorting out when I turned the engine off. Thanks for the help.
Old Feb 10, 2010 | 9:50 AM
maxxman04's Avatar
bad connections and/or a bad battery might cause that. check every connection, at battery, at solenoid, all grounds, have battery tested.
HeavyChevy87
Oct 6, 2021 1:59 AM
180461
May 3, 2017 8:06 AM
MrEarp
Aug 29, 2012 5:38 AM
Chillin014
56
Jun 10, 2012 8:17 AM
KaneII
Nov 7, 2009 2:49 AM
