2001 Tahoe P0442 and P446 won't sart
Old Dec 24, 2008 | 10:55 PM
digarta's Avatar
Default 2001 Tahoe P0442 and P446 won't sart
Noobie here. Stalled and quit. Towed home and started briefly then sputtered and died and now won't start. Any ides?
Old Dec 25, 2008 | 12:14 PM
MDTAHOE's Avatar
Professional Mechanic
Default RE: 2001 Tahoe P0442 and P446 won't sart
po 442 is a evap system small leak dectected and po446 is evap purge solenoid malfunction. It is unlikly that these have anything to do with the no start. It could be possible that it has a mayjor vac leak in the evap system causing the engine to get to much air. look for a giant vac leak
Old Dec 25, 2008 | 11:20 PM
Make sure your gas cap is on tight.
Old Dec 26, 2008 | 8:51 PM
MDTAHOE's Avatar
The gas cap can cause the po442 if it is loose or bad.It is possible that it will cause the po446 if it is missiing but in any case the gas cap will not cause a no start.
Old Jan 22, 2009 | 9:59 PM
digarta's Avatar
Default Well solution found
Fuel filter failed. Evap codes led to replacement of evap vent solenoid. All is well. Hope this helps someone else.
augustus87
Jun 23, 2014 4:41 AM
SRL S10
Oct 26, 2013 4:39 PM
camotruck55
Dec 15, 2011 1:53 AM
EddieClassic07
Dec 11, 2011 1:53 PM
in2pro
Oct 5, 2011 5:32 PM
