2002 Chevy Tahoe Coolant Leak
Old Feb 24, 2012 | 4:47 PM
  #11
I've found checking the underside of the crankcase fill cap to be a good way to check for water in the oil. It presents as a gray jelly-like substance.
Old Feb 24, 2012 | 6:00 PM
  #12
A coolant system pressure test could also tell you if there is a leak...
Old Feb 25, 2012 | 12:26 AM
  #13
66impala4dr's Avatar
Yes the presure is going somewhere I found the block tester and found out the head gasket is bad. But theres no oil in the crank case. So called a dealer and asked them if the bad head gasket will there be water in oil. So found out that there is a way for the head gasket to be bad and the water will never go into the crank case. It would acaully go out though the exhaust and never get into the crank. Hope this help out for anyone that needs some help with there 5.3lt. This is from a master tech mechanic in a local dealer in Florida that I used to work with when I was in Florida.
Old Jan 16, 2014 | 10:45 AM
  #14
Taznas's Avatar
I have a 2002 Tahoe 4.8 with non castech heads and i have a cracked head? Can you reuse the head bolts if I buy new heads? Or are they a one time use?
Old Jan 16, 2014 | 6:11 PM
  #15
Welcome to the forum.
It's not recommended to reuse them especially the newer ones that are torque to strain which I believe requires a special wrench. One of techs here can point you in the right direction.
Old Dec 10, 2015 | 9:32 PM
  #16
Lcastillo's Avatar
New User
Awaiting E-mail Confirmation
I have a 2002 Tahoe 2 wheel drive vortex v8 5.3 an notice I had a squealing noise today an also the low coolant light came on the computer box so I popped the hood to take a look I noticed the squealing was cause it look like oil all over my belt but it smelt like antifreeze so I check the coolant had none in there put water in it an was leeking all over bottom off engine next to oil pan all the water but under the hood went every where even on the alternator an power steering fluid box what could this be
Old Dec 10, 2015 | 9:34 PM
  #17
Lcastillo's Avatar
New User
Also I forgot to add this doesn't mess with performance and is not over heating on the 2002 Tahoe
Old Dec 10, 2015 | 10:56 PM
  #18
Welcome to the forum. You might check the freeze plugs. It also might be the water pump seal.
Old Dec 11, 2015 | 10:05 AM
  #19
frank reid's Avatar
I have a 1994 Z-71 4x4 pickup. The check engine light will come on after I drive it for about 6 - 7 miles, but always goes off when I turn engine off. Will not be on when I start truck again, but once again after about 6 - 7 miles, comes on. Any ideas?
sarahlorrain
Aug 21, 2015 10:05 AM
mygreenihc
Aug 5, 2015 11:09 PM
NeeNeeDE
Oct 16, 2013 8:32 AM
TahoeFalcon
Jun 4, 2012 9:22 PM
95wt
May 30, 2008 3:07 PM
