2002 Chevy Tahoe replacing water pump and draining coolant help
Old Jun 4, 2012 | 8:14 PM
TahoeFalcon's Avatar
Default 2002 Chevy Tahoe replacing water pump and draining coolant help
Hi,
I posted awhile ago on this forum about a coolant issue...
After putting dye in my coolant, I found out that my water pump was leaking coolant, so I took off the pump and removed the hoses and stuff. I removed the lower radiator hose off the radiator and drained it. My new pump is coming tomorrow... should I just put the new pump on and add more coolant? Or is there more coolant I should drain out before adding the "new"? Is there anything else I should do before putting it back together?
Thanks guys!
Regards,
Josh
Old Jun 4, 2012 | 9:22 PM
kevinkpk's Avatar
Originally Posted by TahoeFalcon
Hi,
Thanks guys!
Regards,
Josh
I'm not even going to tackle that.....
WorkHorse2500
May 1, 2014 4:44 PM
karlall90
Sep 25, 2013 10:43 PM
seabeckpuck
Mar 23, 2012 9:13 AM
ambitiousone
Mar 21, 2009 11:28 AM
