2002 Suburban Troubleshooting help
Old Mar 23, 2013 | 11:49 AM
lrodptl's Avatar
Default 2002 Suburban Troubleshooting help
Can anyone help? Thanks.
2002 K1500 Chevy Suburban, 5.3 Liter Flex Fuel, 193,500 miles, just replaced
plugs and wires.
Cold start, runs rough, tripped codes P0171 (2 - one for bank 1, one for sensor
Bank A) and P0174 (also 2 - one or bank 2, one for sensor bank B). Runs great
once fully warmed up.
Intake manifold pressure bounces round 11- 12 and goes to 10 steady once warmed
up
Old Mar 24, 2013 | 11:04 AM
mulmur1's Avatar
You may want to check the air filter. The MAF sensor may be dirty, as a result of the air filter being clogged. Are you running a K&N filter that uses oil. It is possible that you have put too much oil on the filter. Is this is the case, get a K&N cleaner kit and clean the filter and re-oil conservatively. You should also try and clean the MAF sensor or look at replacing it.
You are doing well with 193,000 miles on truck.
kingpinofdisks
Colorado
Jul 10, 2012 11:41 AM
Chriss Bennett
Jan 28, 2012 5:18 PM
taderhold
Jun 7, 2010 8:13 AM
taderhold
Mar 22, 2010 3:32 PM
losfomot
Nov 16, 2007 5:38 PM
