Trans problems on 99 suburban
Old Mar 23, 2013 | 10:27 PM
lucasjames's Avatar
Default Trans problems on 99 suburban
Ok my rear end went out on my burb so I replaced it and now my Trans wont drive in drive or 3 off the start 2 and 1 go but will slip if I get on it.. Will shift through all gears if I start from 1 or 2 and then shift back up to drive plzz help
Old Mar 24, 2013 | 10:58 AM
mulmur1's Avatar
It sounds like you have done a bunch of work on your truck. When you replaced your differential, I assume that you used the same gear ratio and that you refilled the automatic transmission, since you removed the driveshaft. Truly, replacing the rear end should not have any impact on the transmission, if it is the same gear. Was there any transmission linkage removed or altered?
I am sure that you are pulling out your hair.
Good luck.
Old Mar 24, 2013 | 11:12 AM
lucasjames's Avatar
Trans fluid is cherry red still no leaks maybe It could be a sensor or maybe my Trans mest up when my rear end busted im stumped
Old Mar 24, 2013 | 11:27 AM
mulmur1's Avatar
You mention in your note, that the transmission is slipping in 1st. Was it slipping prior to the rear end change? How many miles do you have on the truck. It is possible that the transmission was on its way out. You may want to get a transmission shops take on the problem.
Old Mar 24, 2013 | 11:37 AM
lucasjames's Avatar
Trans was fine befor the switch thats why im stumped
Old Mar 24, 2013 | 11:44 AM
lucasjames's Avatar
Its got 147k
Old Mar 24, 2013 | 12:13 PM
mulmur1's Avatar
Lucas,
When is the last time you changed your Trans filter? It may be clogged. I should have asked you earlier about this. If the filter is clogged, you may get some of the problems you are noting, ie slipping, not shifting properly etc.
Old Mar 24, 2013 | 1:26 PM
lucasjames's Avatar
Havent got to that yet I jut wanted to see if anyone has had the Sam proplem I will change the filter some time this week hopefully that will fix it cuz cant afford to bring it to a Trans shop..but if u can think of anything else it could be I'd be much appreciated if you would let me know thanks
malibuman360
Aug 24, 2013 10:54 PM
lucasjames
Mar 26, 2013 11:08 AM
ukrkoz
Mar 4, 2012 3:16 PM
bouttree
Oct 3, 2009 9:02 PM
monteman85
Feb 17, 2009 5:05 PM
