2003 Burb- Passenger Window Goes Up 1/2 Way
Good afternoon,
I own a 2003 Chevy Suburban and the front passenger side powered window goes up only half way before it stops working. It takes a minute before it continue, it seems to power off. So far, I installed a new motor and assembly at it but the problem continues. I lubricated the tracks with PB Silicone Spray but the issue continues.
Any ideas? Could this be an electrical issue?
Thank you!
Thank you!
I was researching ways to not break the front pin of the switch during removal and I read a comment to try the driver side switch. Both switches have the same results- a really slow window ascension. Since both switches result in the same thing, could it be something else?
Both my driver and passenger side switches were working so I concluded it wasn't the switch. I bought spray silicone to put into the tracks and it seems to be working smoothly and hanging less. Thank you for the replies.
Lesson I learned from this: don't throw parts at a car, start simple.
Kyle Riggs
February 7th, 2012 6:58 PM
