2003 Burb- Passenger Window Goes Up 1/2 Way
Old Apr 29, 2020 | 4:35 PM
BearClaw's Avatar
Default 2003 Burb- Passenger Window Goes Up 1/2 Way
Good afternoon,
I own a 2003 Chevy Suburban and the front passenger side powered window goes up only half way before it stops working. It takes a minute before it continue, it seems to power off. So far, I installed a new motor and assembly at it but the problem continues. I lubricated the tracks with PB Silicone Spray but the issue continues.
Any ideas? Could this be an electrical issue?
Thank you!
Old Apr 29, 2020 | 4:42 PM
kevinkpk's Avatar
Old Apr 29, 2020 | 4:50 PM
BearClaw's Avatar
Thank you for the quick reply! I will go try this.
Old Apr 29, 2020 | 8:07 PM
BearClaw's Avatar
I was researching ways to not break the front pin of the switch during removal and I read a comment to try the driver side switch. Both switches have the same results- a really slow window ascension. Since both switches result in the same thing, could it be something else?
Old Apr 29, 2020 | 9:04 PM
kevinkpk's Avatar
The front pin is a molded part to secure the switch assymbly to the fore arm, nothing to do with the electrical part.
Old May 5, 2020 | 10:39 PM
BearClaw's Avatar
Both my driver and passenger side switches were working so I concluded it wasn't the switch. I bought spray silicone to put into the tracks and it seems to be working smoothly and hanging less. Thank you for the replies.
Lesson I learned from this: don't throw parts at a car, start simple.
Old May 6, 2020 | 8:28 AM
Cusser's Avatar
Aerosol silicone spray into the channels has worked also on my 2004 Frontier power window that was sluggish; that was about 6 years ago.
Luper
Mar 22, 2018 12:06 PM
Kyle Riggs
Feb 7, 2012 6:58 PM
chunk_le_funk
Aug 21, 2011 12:57 PM
Burnett 1500
Aug 18, 2011 1:34 PM
renaldo0613
May 9, 2010 12:13 PM
