2003 programing remote
Old Aug 21, 2007 | 12:10 AM
redbaron's Avatar
Default 2003 programing remote
do you jump the 4 & 8 terminals on OBD11 connector to start the programing.
Old Aug 21, 2007 | 8:47 AM
ZX1100F1's Avatar
Default RE: 2003 programing remote
On the 2003 model you do not jump the pins on the OBD port.
Here are the instructions for prgramming a new RKE transmitter:
[ol]1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to 4 transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation. [/ol]
Old Aug 21, 2007 | 9:16 PM
tahoe07's Avatar
Here is a nice link for programming most remotes.
http://www.programyourremote.com/
Old Aug 24, 2007 | 3:34 AM
redbaron's Avatar
thanks for the information
lspencer001
Jul 20, 2013 1:13 PM
94z28
Nov 26, 2010 12:29 PM
brankin
Astro
Jan 27, 2010 5:49 PM
roger01
Cobalt
Aug 18, 2009 12:54 PM
