2003 Suburban Hood Insulation
Old Jun 5, 2020 | 7:26 AM
monstershow's Avatar
Default 2003 Suburban Hood Insulation
Hello All
The first layer (thin fabric) of the hood insulation pad is deteriorating. It is coming off the pad and falling apart. Is there an option of covering the existing pad or will the entire pad need to be replaced. I can not find any products to install over the existing pad. Of course replacement pads run the range from cheap to expensive. About $300.00 for OEM. Thanks for any info.
Rick
Old Jun 5, 2020 | 11:59 AM
oilcanhenry's Avatar
Originally Posted by monstershow
Hello All
Rick
You might be able to make your own insulation pad if need be or use the cheap ones, then secure it with some 3-M adhesive. $300 bucks is indeed a bit much for this part.
Old Jun 6, 2020 | 9:39 AM
Cusser's Avatar
Especially with the age of your vehicle...
Old Jun 6, 2020 | 1:03 PM
I don't even have a pad
Old Jun 6, 2020 | 2:00 PM
kevinkpk's Avatar
Well, I'll leave that alone......
Old Jun 7, 2020 | 3:02 AM
naked under the hood
Old Jun 7, 2020 | 9:07 AM
Ryan Holland's Avatar
Hello All
Rick
You can always look at various aftermarket options through different companies to help lower the price. Also, if you have the time, take a walk through your local salvage yard. You will probably find plenty completely wasted. But there’s a good chance you may come across a pad in decent shape. I couldn’t see a yard charging more then $10-$20 when you remove it yourself. Good luck!!
smf003
Oct 11, 2017 6:18 PM
rjdjbd
Apr 27, 2016 3:31 PM
CarolinaJ
Apr 17, 2012 7:44 AM
harmonjr
May 17, 2009 10:18 AM
harmonjr
May 11, 2009 9:33 PM
