2003 suburban power issue
Old Nov 8, 2021 | 6:54 AM
bigmike200587's Avatar
Default 2003 suburban power issue
Hello all! Been having an issue with my 03 suburban and I'm hoping for some guidance.
The problem is anytime I get more than about half way down on the gas pedal it the engine starts cutting out/spitting and sputtering.
The car has had an electrical issue since I bought it earlier this year where the dash would blink off start dinging and the door locks to cycle. I read somewhere about a bad ground in the back of the engine and sure enough that connection was bad. I got that wired up but didn't help the intermittent dash/door lock issue.
I moved past the electrical issue and then I started having the engine performance issue.
So far I have changed the coils, wires, plugs, fuel filter, and fuel pump. I also thought maybe the cats were plugged up so I unbolted them for a test drive, no such luck. I have a knock sensor code and O2 codes which have been set since purchasing the vehicle. I thought it could be a throttle position sensor but the sensor reads a smooth graph when testing it with the engine off and running/driving.
Any insight would be appreciated!
2003 Chevy suburban 282,000 miles 5.3l flex
Tyger255
Sep 1, 2019 6:24 AM
sbrenton
Jun 19, 2017 4:03 PM
1gmctruckman
Sep 14, 2015 9:24 AM
Chevygirl Bates
Apr 17, 2011 10:13 PM
medicjack
Nov 6, 2010 5:32 PM
