2003 Suburban Rear Axle / Differential Cover w/Drain
Old Apr 28, 2020 | 9:20 PM
rjdjbd's Avatar
Default 2003 Suburban Rear Axle / Differential Cover w/Drain
I've slowly working my way thru changing out all the fluids on my 2003 Suburban four-wheel drive with a G80 differential. After watching a couple of YouTube videos on how to change out the differential fluid, I was surprised to find that my Suburban does NOT have a drain plug on the differential housing. I have to pull the differential cover, which is far messier and requires replacing the gasket.
I'm looking for suggestions on replacing the differential cover with one that has a drain plug and after looking around online, I see that the prices run all over the place, with many designed for improved cooling, racing or off-road use, etc. I'm looking for a standard-style replacement that doesn't negatively affect anything inside the housing.
Any suggestions as to brand and model?
Thank you very much!
Old Apr 28, 2020 | 10:18 PM
see if you can source a reusable gasket. they don't need rtv and re-install quickly with little clean up required. similar to the reuseable trans pan gasket; my truck has one from oem and it makes changes easy. price is $40
don't get sucked into the aftermarket covers... as you are aware; they use hold more fluid but end up starving the pinion bearing as the oil throw off from the ring gear changes.
Old Apr 29, 2020 | 11:52 AM
rjdjbd's Avatar
I don't mind the cost of the replacement gasket if I have to remove the differential cover. I'm looking to replace the cover with a drain plug to make the fluid change a lot simpler and cleaner.
Old Apr 29, 2020 | 2:10 PM
You shouldn't need to change the gear oil very often. So when you do, it's a good idea to open it right up so you can inspect the condition, clean off the magnet, clean out sludge that collects at the bottom, etc.
Old Apr 29, 2020 | 4:10 PM
rjdjbd's Avatar
I know you're right... I just need to convince myself due to all the extra work for such a simple task.
Kael
Nov 24, 2019 1:53 AM
Hrpchr
Mar 10, 2016 12:57 PM
Wags2003burb
Jan 27, 2016 10:05 AM
lawman34203
Mar 27, 2010 4:48 PM
tatt2kid
Avalanche
Sep 2, 2009 7:16 PM
