2003 Suburban voltage problem
Old Mar 5, 2007 | 3:24 AM
mystrg's Avatar
Default 2003 Suburban voltage problem
I have a new battery and alternator.
The voltage still reads low on the gauge and at the battery!
What is the cause?
What is robbing the voltage?
Old Mar 8, 2007 | 12:36 AM
dkbrucedvm's Avatar
Default RE: 2003 Suburban voltage problem
Are you sure the voltaage is low? What's the voltage at the alternator and the battery?
New doesn't always mean good.
Regards,
David
Old Mar 8, 2007 | 11:12 AM
golfer's Avatar
New alternater or rebuilt alternater ?
There is a big difference between the two... you can't trust the rebuilds.
Old Mar 8, 2007 | 1:39 PM
shnormo's Avatar
What are the volts that you are getting? Could also be something as simple as a bad ground or corrosion or a broken wire.
Old Mar 25, 2008 | 10:24 PM
redchevys10's Avatar
I have the exact same problem 99 s-10 new alternator and new battery. Voltage gauge reads around 11? had the alternator tested, checked cables. Any ideas?????
Old Mar 26, 2008 | 3:19 PM
shawnvw's Avatar
Banned
have you cleaned and tightened the power and ground cables, including the mounting bracket for the alternator?
smittygj
May 9, 2020 9:01 AM
dimento
Astro
Apr 2, 2013 9:21 AM
jpmoore70
Feb 4, 2013 8:18 PM
gbecasfsim
Oct 9, 2012 4:57 PM
pwinstead
Sep 1, 2008 10:20 AM
