2003 Tahoe Alarm goes off for no reason
Old Aug 26, 2009 | 8:41 AM
bc0508's Avatar
Default 2003 Tahoe Alarm goes off for no reason
My 2003 Tahoe alarm has went off the past 2 nights for not reason one time 2 30 am and next night 3 30 am. This is the first time this has happened I have owned it since new.
Does anyone know what could be causing it? Or how can I disable it. Its a factory alarm
The good old horn and lights going.
Old Aug 26, 2009 | 8:55 AM
1.Battery voltage could be dropping out and the alarm senses it as a trigger...
How old is the battery? are all the connections tight? good grounding?
2. One of the sensors has become sensitive to a temperature change as it cools off at night..
3. Someone/thing really did move or attempt to enter the vehicle
4. Gremlins.....
Old Aug 26, 2009 | 9:04 AM
bc0508's Avatar
1. The battery is not that old maybe 1 year.
2. Could be its is getting a little cooler at night now. I am in South Carolina.
3. Not likely even though I live in the woods I am up pretty quick when its done it with gun in hand... Havent seen any thing.
4. Maybe bigfoot
Old Aug 26, 2009 | 9:09 AM
check your battery connections and the ground wire to the batter and chassis, I would bet that voltage anomaly is most likely the culprit.
check the battery voltage with the vehicle off it should be at s bit over 12v 12 point something, try charging the battery with a charger and see if the alarm goes off that evening....
sween22
Feb 10, 2020 3:25 PM
johnhibbs
Jun 25, 2012 10:36 AM
eljicio
Apr 2, 2011 9:34 PM
joelights18
Oct 19, 2009 7:44 AM
mobilemodding
Mar 29, 2009 1:28 AM
