2003 Tahoe Best Heater Hose Connection advice
Old Apr 6, 2014 | 4:28 PM
flbeachfront's Avatar
Default 2003 Tahoe Best Heater Hose Connection advice
I have a 2003 Tahoe and the heater hoses attached towards the wall of the cab are held there by plastic connectors that go bad. I have noticed a method using a Dorman connector, others used a clamp. Is the end that comes out of the truck metal that I can slip a hose over both of those connections? or are they plastic? Would a preferred long term approach to put a hose over it and hard clamp it vs. plastic. Looking for expert mechanic advice, for since I have a leaking water pump at 120K miles all hoses are getting redone later this week as well. Jim
Old Apr 6, 2014 | 4:52 PM
As I understand it, its best to use the spring type hose clamp vs the screw drive hose clamps on vehicles with plastic fittings, as the spring type ones will allow for expansion and contraction of the plastic, whereas the screw drive type do not allow for expansion and will eventually cause the plastic connection to deform and crack eventually breaking apart to pieces...
I don't know if that helped answer your question but I hope it provided some helpful input
Attached Thumbnails 2003 Tahoe Best Heater Hose Connection advice-spring-clamp.jpg   2003 Tahoe Best Heater Hose Connection advice-screw-drive-clamp.png
Old Apr 6, 2014 | 8:06 PM
Default Thanks, yet is the tubing coming through the engine wall metal or plastic?
If the tubing coming from inside the cab, stainless high quality metal screw drive clamps work great, otherwise spring clamp or the dreaded plastic Dorman 840 attachments. Anyone have a really good GM repair manual or experience with those details?
Old Apr 6, 2014 | 8:09 PM
Default Point of reference video.
I would like to avoid all plastic if possible. advice?
tbb2
21
Jan 1, 2021 10:01 AM
AZCardsAndIndyColtsFan
Apr 26, 2016 8:30 PM
justimagination
Jun 20, 2015 10:25 PM
kevinf
Nov 16, 2008 3:32 PM
red891500
Oct 24, 2006 9:20 PM
