2003 Tahoe Driver's seat reversed
Old Apr 8, 2013 | 4:23 PM
hub_cap's Avatar
Default 2003 Tahoe Driver's seat reversed
In order to move the driver's seat forward, the slide bar must be pushed to the rear and visa versa. The passenger seat functions normally. This Tahoe was purchased new and I don't recall if it has always been this way.
Any ideas on what needs to be changed?
Thanks
Old Apr 8, 2013 | 6:49 PM
mulmur1's Avatar
Welcome to the forum.
In your Tahoe, just to confirm; when you press the power seat button, the seat moves in the opposite direction to the direction you push the switch? Ie when you move the switch rearward, the seat moves forward and when you press the switch forward, it moves back? It sounds like the seat connections need to be reversed on the switch to correct the problem. If this has always worked this way, it may be that the wires on the switch are reversed. If this is a new problem, there may be a problem with the seat switch and it should be replaced.
You can get a new switch at your dealer or gmpartsdirect.com
Good luck with the repair.
Dbuseyiii
Sep 20, 2021 9:26 AM
lbi2000
Jul 31, 2014 7:11 PM
jimmys57chevy
Aug 22, 2012 8:45 PM
shadowrider05
Aug 15, 2012 1:11 PM
sardarkhan
May 16, 2012 3:02 PM
