2003 Tahoe firewall grommet leaking rain water.
Old Apr 6, 2021 | 5:29 PM
Z71white's Avatar
Default 2003 Tahoe firewall grommet leaking rain water.
2003 Z71 Tahoe.
Question is: Is my grommet pushed in from audio shop (running wires) or is it supposed to sit flush on the outside lip? I'm pretty sure I'm getting rain water through here. Pictures of your firewall would be great 👍Thanks guys.
Old Apr 6, 2021 | 5:44 PM
kevinkpk's Avatar
Originally Posted by Z71white
2003 Z71 Tahoe.
Does it have a groove on the outer edge? If so, it should set with the groove in the center of the firewall, in other words you should have grommet sticking out past the fire wall on both sides.
Old Apr 6, 2021 | 6:04 PM
Z71white's Avatar
Thanks for the quick reply, it's definitely loose and I can slip my fingers inside the firewall from the edge of the grommet, and it doesn't have a tight fit on the firewall at all. I'm pretty sure the shop pushed it in to slip wires through. I'm just having a hard time trying to fix it. So to clarify, the metal lip is not supposed to be exposed? Thanks again.
Old Apr 7, 2021 | 7:25 AM
kevinkpk's Avatar
I'm saying if the grommet edge is cupped, it should slip over both sides of the opening, you should have rubber on both sides of the metal.
2003 Tahoe
Mar 22, 2017 10:49 AM
whtbuck
Mar 13, 2017 11:51 PM
abrdn419
Jun 29, 2011 5:51 PM
Kimyung101
Jan 2, 2009 5:00 PM
kamikaze124
Jun 17, 2007 6:43 PM
