2003 Tahoe LT - AC frustrating
Old May 31, 2018 | 6:58 PM
Joe Knudsen's Avatar
Default 2003 Tahoe LT - AC frustrating
Let me start by saying I'm no mechanic, not even close so ve gental on me....
so AC is touching hot air ... I have replaced everything I can think of
accumulator
compressor
air lines lines
Belts
bottles and bottles of 134a
go to all the pretty gauges
blows hot still and overheats at idle.... never get cold all gauges read as (youtude tells me these should be)
Old May 31, 2018 | 9:55 PM
-put the gauges note the static pressure (pressure with the system off for 10minutes) and ambient temperature. post results.
-start the engine and run the a/c system; does the compressor run, does the compressor short cycle? turn on for 5-10seconds and then shut off.
-does the high side pressure go over 250 psi pretty fast
-are the cooling fans turning on?
Old Jun 6, 2018 | 2:37 PM
System off blue Line reads 51 red is at 50
The compressor does not run when the air conditioner is on it will turn on the second I turn the air conditioner off
When I turn the AC off the red line goes up to about 125 and blue side drops to 20 and then goes back and sits around 58
Radiator fan is not on and it's the compressor Cycles about every 5 to 10 seconds like you said
Old Jun 6, 2018 | 2:53 PM
Left the air conditioner off which for some reason engages the clutch for 10 minutes attached photo is the gauges at 10 minutes the moment I go into the truck which is still hot and push the air conditioning button the compressor disengages and never turns on also two notes the fan on the radiator does not turn on and the temperature of the engine was around 210 and climbing
Thanks for any and all assistance
Old Jun 6, 2018 | 8:15 PM
the first thing to address is why the ac is coming on when switched off and why it off when switched on.
how I think it should work is the a/c "on" switch grounds a signal from the pcm. the pcm provides power on the wire to the ON switch...the wire then goes to the pressure switch then to chassis grd...so if you check the wiring at the hvac module c1 connector... pin b11 white wire should have power from the pcm and the a12 dark blue wire should have grd if the pressure switch is closed(its closed with the system charged with refrigerant)
do you have automatic or manual system?
Old Jun 6, 2018 | 8:53 PM
All that is Greek to me I will google in am, see what I come up with
thanks
Old Jun 7, 2018 | 8:13 AM
find a wiring diagram for the hvac and a/c system
Old Jun 7, 2018 | 12:27 PM
{tpc}'s Avatar
Isn't the clutch just a solenoid that pulls in? I wouldn't think it would be more complex than a power and ground engaging it, and even if it was plugged it backwards, I don't see how it could ever engage?
I wonder if there is a wrong relay in the fuse box or something? Something that is normally closed when it should be normally open? That would explain reverse operation of the switch. As for the fans not coming on...somewhat of a mystery there.
Old Jun 7, 2018 | 7:38 PM
the fans come on when turned on by the pcm....if the compressor is turning on when the pcm thinks its off....the pcm won't engage the fans.
Old Jun 11, 2018 | 9:33 AM
Default Leak
Ok I have set an appointment with shop for ac
now raditor is leaking from behind fan .... I can't find a hose leaking not sure what is behind the fly wheel (?) But seems to be coming from there
