2003 Tahoe oil leak
Old Jan 25, 2015 | 9:57 PM
NineEchoOne's Avatar
Default 2003 Tahoe oil leak
I have a 2003 Tahoe that has developed an oil leak around the oil filter. The filter is tight, but it has an pretty heavy leak. What are some ways of fixing this? Three or more filters have not helped. Can the fitting the filter crews onto be replaced? Other ideas? Thanks.
Old Jan 25, 2015 | 10:09 PM
Make sure the mounting surface for the filter is clean with no remnants of an old o ring or gasket. Also make sure that an o ring from an old filter did not not come off the filter and is still there making it 2 o rings which would cause a leak.
Old Jan 26, 2015 | 12:17 PM
Scotiapilot's Avatar
check top of the block in the back for oil leaks that are dripping down.
Old Feb 15, 2015 | 10:52 PM
Default The Tahoe leak
Filter ring is clean. No leaks on top. It is coming from the oil filter mount (?)
whtbuck
Mar 13, 2017 11:51 PM
Eric Sherden
Sep 24, 2013 1:21 PM
PastorK
Mar 1, 2010 9:09 PM
95wt
May 30, 2008 3:07 PM
trush
Jan 1, 2008 9:27 PM
