2004 AC Not Cold - just cooling
#11
RE: 2004 AC Not Cold - just cooling
I'm sure you are right about that
I took time to read some of your replies to others and apparently you might know answer about my AC...It's just how can I get it out of ya?
#14
If you read my first reply to you it was nice.
It might not have had correct information because I didn't fully understand your problem but at least I gave it a go.
In reality though A/C systems are hard to fix at home, no cop-out just the truth.
Here's the first thing that you need to do:
The A/C auxiliary (rear) evaporator module is at the rear passenger side, it is where the water came from, there is a drain tube that allows condensation from the evaporator core to drain outside, if it becomes clogged it will allow the plastic module (housing) to fill partially with water, when you come to a stop the motion will cause the water to slosh and spill out onto the floor board.
There is a drain hole (black rubber nub flattend on the end) underneath the vehicles just aft of the right rear tire (above the tailpipe) , it is not hard to locate, once you find this rubber drain tube take a straightend coat-hanger (or similar) and run it up and down in the hole to dislodge whatever is obstructing the drain, water will flow out when you get it.
Do this first it may likely completely solve your problem.
#15
ORIGINAL: ZX1100F1
The A/C auxiliary (rear) evaporator module is at the rear passenger side, it is where the water came from, there is a drain tube that allows condensation from the evaporator core to drain outside, if it become clogged it will allow the plastic module (housing) to fill partially with water, when you come to a stop the water will drain out onto the floor board.
There is a drain hole underneath the vehicles just aft of the right rear tire, it may be hard to locate but you need to prevail, once you find take a straighten coat hanger or similar and run it up and down in the hole to dislodge whatever is obstructing the drain, water will flow out when you get it.
Now on to my AC....I will sure ream the drain tube out but you say "...just aft of the right rear tire..."
I currently have two drains draining.....1 between engine and passenger area at firewall AND 1 about middle of passenger side 2nd door. That second one seemed to me to be too far forward to typically relieve the condensation that spilled onto the floor out of the "vent/grate" as well, I did not think there would be 3 drain tubes?
Maybe the "draining" I see for #2 is wicking along the chassis from the rear where the tube is clogged? I did not get under it and verify it is a tube there.
Thanks
#17
ZX... On the max A/C setting...what should the output temperature be on the 2007 Tahoefrom the front andrear vents?
Also, it seems the under heavy acceleration that when my A/C is on it temporarily blows warmer air than usual.... is that normal?
Thanks
Thanks
#18
The low temperatures at the vents will depend on the outside air temperature and the relative humidity but the front systems lowest temp spec is 41F and the rear is 45F on cool days.
The rear (aux) system always runs about 3-4 degrees warmer then the front (main).
On days near 100F for instance the main system will put out about 60-66F (this is it's normal range at 100F)
If you step on the accelerator pedal hard (beyond 3/4 travel) the A/C compressor will be disengaged automatically to provide maximum power at the rear wheels, when the throttle is relaxed the compressor will then be re-energized.
