2004 AC Not Cold - just cooling
Old Aug 13, 2007 | 10:37 AM
  #61
BonesNTX's Avatar
Default RE: 2004 AC Not Cold - just cooling
Camry Lost out as not high enough MPG for my daily drive
Still need my TAHOE AC COLD!
Old Aug 13, 2007 | 1:31 PM
  #62
uraijit's Avatar
Static pressure is what your pressure is at when the vehicle is off. Also asked if the compressor is cycling off ever with your low pressures (150ish). Read back through the thread and look at all of the questions that have been asked, and answer to the best of your ability. And maybe you'll get answers (to the best of our ability).
Old Aug 13, 2007 | 1:40 PM
  #63
BonesNTX's Avatar
Yes the compressor cycles at times. Seemingly not much if at all when freon level drops (normal)
Have never in my life checked static pressure on any car or home Condensor so thanks for teaching me something there. Even though I don't yet know whaat it should be.
The travelling mechanic was supposed to be back last night from 9 day trip up north to see Family. Plan was that he would have the TAHOE at the GMC dealer today but I have not heard from him yet.
Thanks
Old Aug 13, 2007 | 2:01 PM
  #64
uraijit's Avatar
What do you mean "freon level drops"? Are you losing refrigerant? If so, that's number one priority, fix the leaks, then move on to other things.
If the compressor is cycling off before it reaches the proper high-side pressures, and your low-side isn't dropping, one of your pressure switches is probably bad. If the compressor isn't cycling off, and it's just not able to get your high-side up to where it needs to be, then you're looking at a compressor that's on its way out.
My money's on a switch though, since the problem is intermitent.
Old Aug 13, 2007 | 2:20 PM
  #65
BonesNTX's Avatar
ORIGINAL: uraijit
Thanks for your reply
Seems to be loosing some freon as it was mentioned way back when on this deal. We checked for leadks with a sniffer (went off a bit at the real evap by probing from bottom next to tire)
As well we put die in but could not see any signs so opted to drive for a while which has now been 8 days. Plan was to have been in shop today for good look for die, even on rack.
If no die is ween then the freon will be removed and re-charged to be monitored daily until problem is pin pointed.
My friend has said all along ....Compressor probably is leaking at least and therefore replace.
My 1969 MACH I had the same compressor on for 36 yrs until I sold in 2005. freezing Cold of course...Even on 134.
New Chain saw at about 2 hrs use at home....broken
New 5 Ton American Standard Central AC....That has caused $8,200 damage to my house...AND they can't figure out how to set it yet.
Amazing where we have gotten to
Old Aug 14, 2007 | 5:00 AM
  #66
BonesNTX's Avatar
Now my Travelling Monkey Mechanic cannot get to it until next Monday due to him leaving town again to school in Dallas and myself unavailable a couple days this week. Arrrrgh!!!
Oh well I'm about 1 more can of freon to having it in his shop!
Thanks for the switch tip...I'll tell him to be sure to check for that as well once leak is found.
Old Sep 6, 2007 | 2:46 PM
  #67
BonesNTX's Avatar
Found you guys again FINALLY!
Just got my TAHOE into MR Goodwrench's today as my friend the Roving Mechnanic is in town for a couple days.
Knew you all were worried so I thought I'd check in and will notify you all when the problem is found and remedied.
til then................[sm=ttiwwp.gif][sm=americanasmiley.gif]
Old Sep 7, 2007 | 9:01 AM
  #68
BonesNTX's Avatar
Well, it's the rear evap that is leaking slowly. Surely due to not draining as we talked about early on. $280 for the part from the dealer + 4 hours labor + re-charge is the estimate thus far.
My friend (the Roaming Mechanic)and I will take aSaturday off together from fishing soon and R and R it in my driveway under my shade tree in front yard when he returns back to town after more Hyundai school he has to leave in order to attend next week.
They did fully charge it so I guess that means the evap rust hole is soon to get bigger with the +pressure and therefore the coolness will haveless duration.
Anybody know where to get that evap any cheaper?
Livin large in TEXAS! [sm=americanasmiley.gif]
Old Sep 25, 2007 | 2:32 AM
  #69
uraijit's Avatar
I know it's a bit late, but, Ebay.
Also, Aluminum does not rust...
Old Sep 25, 2007 | 7:52 AM
  #70
BonesNTX's Avatar
Sure....you can buy anything on Ebay
Aluminum oxidizes = corrodes Maybe I said rust but I'm rather aware it doesn't "rust"
2 Mechanics at the Stealership said it was corroded to the point of making a hole and leaking freon due to the drain being plugged for who knows how long.
Factory defect if you ask me
