Last edit by: IB Advertising
Browse all: Interior
- Chevrolet Silverado 1999-2006 GMT800 Why Do Vents Blow Only Hot or Cold Air
Guide to diangnose trouble and recommended solutions.
2004 Suburban AC - Blows HOT
I have 2003 Chevy Suburban that is also blowing HOT Air on AC mode both on the front vents (Driver and Passenger sides) and also at the back vents for the 2nd and 3rd row. I hope there is anyone out there who can help me out what the problem is and guide me in rectifying this issue. Thanks
If your 2003 has a separate small AC belt like my 2005 does, check to see if that's broken.
Check if compressor clutch is actually engaging.
Could be a stuck actuator under the dash.
So I say take it in to a real AC shop - not a speedy lube !!! As it sounds like you don't experience in AC.
I found the actuator on the passengers side, where the air vent is and removed the 2 screw closest to the passenger door and pulled down the plastic cover to expose the actuator thats causing this issue, then turned on the A/C (mine starts up cold then turns hot) so when it was cold I disconnected the wiring hardness before it switched to hot. This has lasted me 2 weeks so far until I can figure out my next move.
This simple actuator calibration worked for me,
Place the ignition switch to the OFF position.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
>Remove the HVAC/ECAS fuse (which is located in the fuse box under the hood) for a minimum of 10 seconds. <o
></o
Install the HVAC/ECAS fuse. <o
></o
Start the vehicle. <o
></o
Wait 40 seconds for the HVAC control module to self-calibrate. Do not adjust the A/C controls until after 40 second or so.
At first the air was very hot then it went to cold and all was well again. Good luck. <o
></o
</o
ffice
ffice" /><o
></o
></o
></o
></o
></o
>If the vehicle is already powered off, how would popping a fuse out of its socket have any affect on its memory?
My problem just started out of the blue. When it happens, I simply put the vehicle in park, turn it off, restart and ac starts working fine. This has happened twice in the last 3 days. Happened weeks apart a couple of times, all since the end of June. Last time it happened, I noticed that ac was blowing cold, then all of a sudden started blowing hot.
Farmerluke
Jun 25, 2013 8:13 AM
