2004 suburban chirping noise in motor
Old Sep 8, 2013 | 2:31 PM
Michael Criswell's Avatar
Default 2004 suburban chirping noise in motor
I have a 2004 suburban 5.3 flex fuel has a chirp in the motor thought it might be the belt or pulley so i pulled the belt off and it still made the noise. please help
Old Sep 8, 2013 | 2:46 PM
Welcome to the forum...good thinking on the belt removal
did you also remove the AC compressor belt as it should be separate....
If so then the only thing left is the crank shaft turning, I'd check for any thing bent or rubbing on the harmonic balancer/pulley
Old Sep 8, 2013 | 3:07 PM
did not know it had 2 belts will try that after i get done changing the transfer case it went bad to. thx for the reply
nytahoecop07
May 31, 2021 1:42 PM
Jenkins
Nov 3, 2011 1:39 PM
valvano
Jun 29, 2011 12:34 PM
Kevinh111
Oct 13, 2009 8:54 PM
dakine503
Oct 2, 2007 8:24 PM
