2004 suburban LS - Need to find a switched fuse to use for a Dashcam
Old Mar 28, 2022 | 7:57 AM
Mah's Avatar
Mah
Question 2004 suburban LS - Need to find a switched fuse to use for a Dashcam
Which fuse is switched on in the engine compartment fuse box that i can tap into for dash cam power?. I would like to tap into it to run dash cam. Cigarette lighter and other power outlet is constant on. If none in that fuse box under the hood, then any recommendation for buse box near driver side panel near the door panel?
Old Mar 28, 2022 | 8:24 AM
repairman54's Avatar
Try the radio fuse. Don't use any of the powertrain fuses to avoid issues.
Old Mar 29, 2022 | 12:13 PM
Mah's Avatar
Mah
I checked Radio fuse. Some how it also has 12 V constant power. I found another 15 amp fuse. that one is for trailer light. I may use it. I am waiting for fuse tap wires. Once it arrives i will check it out and update hear.
Old Mar 29, 2022 | 10:20 PM
Mah's Avatar
Mah
Red face
I used 15 AMP fuse for Trailer lights. It worked fine. So now i have cigarette lighter for switched on and other power outlet constant on. Thanks for your help.
trund
Sep 18, 2020 9:25 AM
Super-6-1
May 14, 2018 10:17 PM
Travis Dodge
Sep 5, 2016 12:29 PM
MrBOFH
Nov 16, 2013 10:25 AM
Christopher Krumholt
May 17, 2013 6:10 AM
