2004 Tahoe Z71 Heater Hose Assembly
Old Jan 25, 2016 | 5:25 PM
TreyWaltman's Avatar
Default 2004 Tahoe Z71 Heater Hose Assembly
hey guys my question is about the hose that is connected to the water pump and has a T connector that has a smaller hose going to the fire wall and a larger hose going to the coolant overflow tank. The T connector has dry rotted or something so it has a small hole in it so it is leaking. What is the best way to fix it? Can I get a new "T" connector or should I get the whole heater hose assembly?
Thanks!!
Old Jan 25, 2016 | 8:43 PM
cleveland63b's Avatar
I believe it usually comes as an assembly but if you shop around enough you might find the connector/fitting
if its dry rotted personally i'd do the whole assembly
Old Jan 25, 2016 | 9:57 PM
justimagination's Avatar
You might try YouTube, lots of info there. Good luck.
David g.
Old Jan 26, 2016 | 8:39 AM
Thumbs up
Thanks for the response guys! David i was on YouTube yesterday and couldnt find anybody fixing the same problem most of what i found were people fixing the connector that goes into the fire wall or replacing the water pump and/or coolant tank.
Love this site lots of info!!
