2005 suburban 1500 - abs light; A/T issues
Old May 16, 2010 | 9:10 AM
blkzoe's Avatar
Default 2005 suburban 1500 - abs light; A/T issues
My 2005 suburban was running fine yesterday. 61000 miles. Started it up this morning. ABS light and brake warning light illuminate with warning bells. In drive, it won't get out of 1st gear. No shifting period. I've seen these symptoms on other forums, but no resolutions to the issue(s). It's certainly electrical, not mechanical. Any suggestions? Thanks.
Old May 16, 2010 | 12:13 PM
LARIDERS's Avatar
a abs light and brake light can mean trans problems. The code needs to be scaned to see what is wrong. when you get the code you should be able to pin point whats wrong.
Old May 16, 2010 | 7:00 PM
blkzoe's Avatar
Default Codes
No codes were thrown. Already checked.
Old May 16, 2010 | 7:11 PM
I would check the condition of the battery and also the grounding of the battery to the chassis, the ground cable needs to be very low resistance.. poor electrical connections can cause strange things
Old May 30, 2010 | 5:31 PM
matco's Avatar
what cause abs and brake light to come on and motor run constantly
Old Jun 1, 2010 | 4:22 AM
blkzoe's Avatar
Default Resolved
Well, here's one for the books. Apparently, the wiring harness to my speed sensor in my transmission had developed a short. I took it to the dealer, they found and fixed. $300. Runs like a charm. I was thinking ABS module at about $1300. NOPE!
Old Jun 9, 2010 | 9:52 PM
Welcome to the forum.
What year, model, etc? Motor runs constantly means what?
agoliver2
Oct 25, 2021 3:14 PM
agoliver2
Camaro
May 16, 2017 4:00 PM
Scott N Vanessa Weaver
Dec 28, 2012 3:58 PM
brettweir78
Jun 1, 2011 10:05 PM
Deteoni
Mar 28, 2009 1:39 PM
