2005 Suburban 2wd to 4wd Conversion
Old Mar 3, 2014 | 11:37 AM
isaias_1's Avatar
Default 2005 Suburban 2wd to 4wd Conversion
Ok, First of I want to say to all the people out there that are going to say sell it and buy a 4x4. Thanks can't do that as I won't get enough to buy another suburban in 4x4 and funds are what they are.
So, I have a 2005 Suburban Z71 fully loaded with everything except the 4x4. I bought it used and never needed the 4x4 until now. I am military and leaving for Alaska in the summe and need 4x4 there. I need all the help from you the forum to help me do this conversion. I know I need front differential with axles, tranfer case, transmission, and what else? Any help suggestions, or parts are welcomed. I am station out at edwards afb, ca and would love to get this done here in the next 2 months. Thanks in advance.
Also, my buddy has a 700R4 that is 4x4. I know it is older and not computer controlled would this be possible with say a flash to the computer to delete the traction control and computer controls of the tranny or not? Thanks
Isaias Carrillo, TSgt, USAF
Old Mar 3, 2014 | 12:34 PM
trainwreck91's Avatar
From what I understand, and a financial point if view. Your going to spend the same if not more on parts than selling and buying a 4x4. I know its not what you want to hear. But calculate what its gonna cost you, not including any issues/problems you're going to have along the way.
Old Mar 4, 2014 | 11:32 AM
hicksvilleshick's Avatar
x2. your going to spend far more to convert than to trade off for 4x4... Unless you've got a really good junk yard hook up...
Old Mar 4, 2014 | 12:50 PM
isaias_1's Avatar
Ok. I see what most people as saying. Again I have a donor truck lined up now. I can get everything for $2500 from an 04 burb with 4x4 except the tcase. what do you all think? Can it be done?
Old Mar 4, 2014 | 5:24 PM
If you have a donor. I don't see why not. You should be able to take all the parts and bolt them on. Then run the wiring and controls
Old Mar 13, 2014 | 11:29 AM
isaias_1's Avatar
Thanks trainwreck91. I got another question. I found a pretty good deal for a rear diff and from diff brake to brake for $800 maybe less from an 02 Tahoe will this work also? No trans of tcase. What do you think everyone?
Old Mar 13, 2014 | 11:54 AM
SWHouston's Avatar
Keep in mind that the front and rear axel ratios MUST be the same, and, the tire diameters as well.
Old Mar 14, 2014 | 9:12 AM
isaias_1's Avatar
Both axles are coming off an 02 Tahoe and I believe he saird they where a 3:73 ratio. What other advice can you guys give me?
Old Mar 14, 2014 | 11:53 AM
SWHouston's Avatar
Nothing comes to mind immediately, only to wish you good luck with your project. Keep us updated on your progress.
Old Mar 14, 2014 | 11:11 PM
blueinterceptor's Avatar
Doesn't z71 mean it had 4x4 already?
