2005 Tahoe LT
Old Dec 17, 2014 | 10:45 AM
Mtnbiker41's Avatar
Default 2005 Tahoe LT
My Tahoe has developed a rubbing/low grinding noise that seems to be coming from the rear axle. When I accelerate I can not hear the noise, but when I let off of the gas and the vehicle is coasting you can hear it very clearly. I took it in to a local shop and they checked all the wheel bearings and they said they were fine. Any help would be appreciated.
Old Dec 17, 2014 | 2:49 PM
SabrToothSqrl's Avatar
Default driveshaft
I suspect the rear driveshaft / u-joints.
When accelerating/decelerating you are changing the angle of the driveshaft by a few degrees as the axle twists on the springs. It may be enough to notice in the shaft if it's not in good shape.
PeterR
Feb 13, 2007 10:09 AM
alek_forum
Nov 2, 2006 9:58 PM
luigi1018
Oct 1, 2006 8:28 AM
