2005 Transfer case DIY, what else
Old Apr 3, 2021 | 12:29 AM
BurbunRunner's Avatar
Talking 2005 Transfer case DIY, what else
I just got a 2005 3/4 ton Burb with almost 200k on the clock and it is in need of a new transfer case. While I am down there, what else should I check out or just replace.
I plan to tow a camper with the family and want to make sure I cover my bases while I am down there. Any suggestions are appreciated.
Old Apr 3, 2021 | 2:18 AM
oilcanhenry's Avatar
I always recommend the use of dielectric grease, 4WD or not. Keeps water and corrosion out, which can happen on any vehicle. Makes pushing the connector in easier too, just don't apply too much.Sorry to hear about your transfer case.In that I'd regard I would definitely go synthetic. I use Royal Purple, but any good synthetic gear lubricant recommended for your unit will do well.
Old Apr 3, 2021 | 10:11 AM
check both driveshaft u-joints while the shafts are out. move each joint thru its range of motion....replace any that feel rough or tight.
Old Apr 4, 2021 | 7:55 AM
repairman54's Avatar
And drain / refill the diff's with a synth. lube also.
Old Apr 4, 2021 | 9:31 PM
Indeed so. Might as well get it all done at once.
Daniel Acosta Sr
Jun 22, 2020 10:07 AM
9Wardfinist
Jan 18, 2020 12:34 AM
2005burbMike
Aug 5, 2012 3:05 PM
mhardy2
Nov 8, 2011 12:59 PM
diggerdpilot
Apr 15, 2007 11:42 AM
