2007 Escalade > 2007 Tahoe Tail light swap
#93
RE: 2007 Escalade > 2007 Tahoe Tail light swap
In regards to the Denali Lights.
Colorado Chief mentioned on the forum that the denali lights are plug and play. I just received my denali lights and thought I would be able to plug the harness in from my tahoe. It seems the little nothces that hold the bulbs in place are not the same size in the denali housing as they are in the tahoe. The tail light harness has a larger notch than the openings on the denali light housings? Did you/anyone have to cut, or somehow modify the denali holder notches so they tahoe harness would fit in?? Please, any help asap would be great! THanks, Landon.
#94
Nevermind! I got the denali tails installed! They worked with very slight modification! I love them. They look much better than the factory tails, IMO.
#96
yeah i actually like them better too i got a set the other day and should be picking them up from my painter tommorow (i had them tinted black i think they are to bright red )i allready had them in on monday with those spider led and dam they look good!!!!!!!!
#97
ORIGINAL: sjenkinzz
Konasmrz....Whats the status on your wiring of the lights? Have you been able to find the euro tail lamps?
Rest assured I'll post a complete write up once I get this done; probably late next week.
#98
Here is a set of aftermarket tails I found on ebay!
http://cgi.ebay.com/ebaymotors/2007-...92599464QQrdZ1
#99
We knew they'd show up eventually. Hell of a lot cheaper than doing the Eskys! I still think I prefer the look of the Esky LEDs. But at least those versions don't require you to change the vent caps to match the lines. We'll see after I get them done.........
Hey Landon, maybe you should order a set to see if you like them better than the Denalis you just installed!
#100
those tails havent even arrived to the states yet but they are on the way this guy is direct with the manufacture if got the same pic emailed to me last week from the manufacture there also going to come in chrome ,black and smoked
