2007 Liftgate Problem
Old Mar 27, 2025 | 1:05 PM
  #51
Farseer's Avatar
Today, I had an unlock failure on my 2007 Chevy Tahoe LT 5.3L. Here are some specifics. Drill the marked circle, but I recommend you drill it a bit bigger than 1/8th inch. It was a bear releasing it using the 1/8th-inch hole. I drilled two-bit sizes larger (see pic below), which made it much easier. In my case, I could hear the solenoid click every time I hit the button (indicating I had power and it was trying), but the latch wouldn't disengage. I off road a lot and assumed dirt and dust was making the mechanism stick after 235000 miles.
To be clear, you will be poking in at a slightly downward direction to hit the release. You can feel around with your coat hanger or metal rod until you find something that gives. I succeeded with a coat hanger, but the second time I found it easier to use a slightly stiffer and larger metal rod (drip system hook for poking down irrigation drip lines). Once released, I blasted the latch with WD40, removing dirt with Q-Tips and paper towels. I worked the latch back and forth, sometimes having to rerelease it manually as it would get stuck. Eventually, the electronics released it reliably, and I kept cleaning and working it until it moved smoothly.
I've left the little metal rod in my car for future emergency use.
Hope that helps.
Cleaned latch below.
deanstnt
Jul 2, 2015 8:01 PM
Texas07Sub
Dec 16, 2014 10:39 AM
The_Stees
Mar 5, 2013 8:20 AM
Big Oakden
Aug 19, 2012 8:42 PM
Mike@VengeancePCM
Feb 22, 2011 7:47 PM
