2007 suburban 2500 4WD issues!! Please help!
Old Feb 9, 2015 | 7:03 AM
nos822002's Avatar
Exclamation 2007 suburban 2500 4WD issues!! Please help!
The 4wd was working fine last night. Today, I go to put it into 4 hi and the service light comes on and all I get is a blinking light on the ****. When I tried to drop her into 4 lo, the truck gives that little jerk like they all do when you put it into 4 lo, but the front wheels won't pull. I haven't played with these newer vehicles, so I'm lost as to what to do about it. Any help will be very much appreciated.
Old Feb 9, 2015 | 12:55 PM
UNDERSCORE's Avatar
Is the connector on the axle actuator broken of off it's connection? When I disconnected mine to check axle / hub function, I got the blinking light at the ****, the SERVICE 4WD on the screen and the front axles weren't locked.
Old Feb 11, 2015 | 5:47 AM
gsferraro's Avatar
You may want to have the tccm(transfer case control module) scanned for codes.
Old May 10, 2015 | 9:35 PM
nos822002's Avatar
sorry for the extemely lengthy time response. so I never did figure out the issue. one day, the 4wd started working when i was on the way to the dealership. hasn't failed since.
Old May 11, 2015 | 10:16 AM
SWHouston's Avatar
Often times various problems arise, and it usually is from infrequent use of our 4WD. Things can get sluggish, and we forget that the Case Fluid should be changed too.
Now that you have it working, set a schedule (like once a month) to run it through hi and low ranges several times to keep things stirred up.
The adage "use it or loose it" applies here.
rickybobby2189
13
Sep 21, 2021 12:16 AM
breezy
Feb 9, 2015 6:01 AM
beezey
Nov 24, 2011 4:01 PM
vpbho
Nov 1, 2010 10:08 AM
Suburbanewbie
Feb 4, 2010 7:15 AM
