2007 suburban cranks a long time before starting
Old Aug 28, 2017 | 10:11 AM
dan2138's Avatar
Newly Registered
Default 2007 suburban cranks a long time before starting
noticed the fuel pump kicks on 10-15 seconds after I turn the key to the on position, shouldn't it pump right away. I had a problem with the ground cable and fixed that but I wonder if I fried something in the mean time, also ever since I got it ( 2 years ago ) the fuel pump is very loud. I feel like the pressure is bleeding off when its not running
Old Aug 28, 2017 | 10:31 AM
If the fuel pump is very loud and bleeding back into the tank, you should replace it before it goes completely out and you get stuck somewhere. Don't get a cheap pump, they are not worth it with the labor involved in replacing them. Only get Delco or Delphi.
