2007 Suburban Driver's Heated Seat Not Working
Old Aug 14, 2019 | 8:21 PM
KChevy75's Avatar
Default 2007 Suburban Driver's Heated Seat Not Working
Figured I'd throw this out here before I start troubleshooting the problem.
I have a 2007 Suburban LTZ. The driver side heated seat function will not work from the buttons. The lights do not illuminate in any way when a button is pushed. However, when you remote start it when it's cold out, The lights on the door illuminate and the seat heater works. As soon as you turn the key to on, the lights go off and the seat heater turns off.
I'm leaning toward an issue with door module where the buttons are. .
Any thoughts?
Old Aug 15, 2019 | 5:03 PM
KChevy75's Avatar
So I scaned all the modules in the suburban and there are no related error codes. I'm going to pull out the door module, take it apart and see if there are any broken solder joints or if maybe the contacts need cleaning.
Old Aug 24, 2019 | 8:07 PM
KChevy75's Avatar
I played around with the buttons a little bit and was able to get it to turn on after numerous presses so it looks like the problem is the button contacts. I'm not sure if I need to take the door panel off to remove the module but I'll certainly post back here once I have some time to work on it.
fishin-frog
32
Mar 9, 2025 10:02 PM
SabrToothSqrl
Apr 11, 2018 9:50 AM
SabrToothSqrl
Apr 27, 2017 9:32 PM
barefootboy
Jun 8, 2016 11:06 AM
bhepler
May 16, 2010 5:54 PM
