2007 Suburban grinding transfer case only in 4WD
Old Nov 15, 2020 | 2:30 PM
Liffa's Avatar
Default 2007 Suburban grinding transfer case only in 4WD
Hi,
I have a 2007 Suburban LTZ with a transfer case problem. The other day I heard a grinding noise for a few seconds whilst driving slowly with the selector in AUTO, it then dissappeared. Today the noise came back, but now even when the car is not moving and I shift gear. It doesnt seem to matter what gear I am shifting to or from. The noise goes away when in 2WD. I managed to record the noise.
https://youtu.be/Tx-b4Y_ldjo
Any ideas what could be wrong? I read something about a snap ring, is there one on the output shaft for the front that could break? Thanks
Old Nov 16, 2020 | 6:57 AM
repairman54's Avatar
Running it on a lift is the sure way to listen to see exactly where the noise is coming from is a first step. Everything else a just a guess.
Old Nov 16, 2020 | 7:10 AM
Liffa's Avatar
We have located the noise to the transfer case. We discovered that it makes this noise even when the engine is not running and I am shifting gears in 4wd/auto mode. I am thinking maybe it has to do with the transfer case electric motor somehow...
Old Nov 16, 2020 | 1:59 PM
PNW NBS Z71's Avatar
Encoder motor likely cause but how long since fluid was changed and are you driving in Auto or 4wd on dry pavement?
Old Nov 16, 2020 | 2:21 PM
Liffa's Avatar
Fluid changed only 4 months ago and the old fluid seemed fine. I emptied the fluid again yesterday and at least I couldnt find any metal in there. I have been driving in auto for a while, I guess I must have forgotten to put it back to 2wd.
Old Nov 16, 2020 | 9:35 PM
spunebil's Avatar
in auto you can drive on dry pavement , but not when in 4wd. I have had 3 jeeps , 2 of which I wheel off road at offroad parks , had np231, np242, and dana 300 transfer cases. 231 and 300 are part time , 242 is full time/ part time . the one in me surburban is a sorta of a full time with the auto selected and part time when 4 wd selected. part time is for gravel, dirt, snow, ice etc. full time can be used on dry pavement , but eats gas !
Old Nov 17, 2020 | 6:46 PM
spunebil's Avatar
a wee bit off topic , but what boat is your picture ? I was plank Owner on USS Carl Vinson CVN 70 . I wheel jeeps now tho LOL
Old Nov 17, 2020 | 7:08 PM
That is the USS Kitty Hawk CV-63. I was ships company from Feb. 1972 to Dec, 1975. Two years of Vietnam War and 2 years peacetime.
Old Nov 18, 2020 | 8:29 PM
spunebil's Avatar
still off topic for forum , but once a SQUID always a SQUID I was HT/DC 78-83
Old Nov 19, 2020 | 6:21 AM
You should read thru this thread I started on another forum that is all military stories: https://www.tahoeyukonforum.com/thre...-force.118133/
