2007 Suburban High Beams won't turn off
About once every 2 weeks my high beams won't turn off when i turn off the headlights and the car. The only way to turn them off is to turn them on and off a bunch of times them they eventually turn off. Recently sometimes they also won't turn on. Only if I turn them on and off a few times do they finally come on. Sometimes if I turn them on they don't turn on right away but eventually turn on.
what is the stalk switch and where is it located, i have the same problem with my 2007 suburban and the only way i can turn the hi beams off now is by removing the fuses
Welcome to the forum.
The "stalk switch" is the turn signal lever. Pushing it forward turns the hi-beams on, pulling it back is for "flash to pass", a momentary all beams on. Make sure it's not in the forward hi beam position.
Ummm... well the manual says the hi beam headlamps relay is on a non-serviceable PCB....
Important: Relays listed below are non-serviceable Printed Circuit Board (PCB) relays and are internal to the block.
BCK/UP LAMP PCB Relay
VEH BCK/UP Fuse, TRLR BCK/UP Fuse
DRL PCB Relay
DRL Fuse
FAN CNTRL PCB Relay
Cooling Fan - Right
FAN HI PCB Relay
Cooling Fan - Right, FAN CNTRL Relay
FAN LO PCB Relay
Cooling Fan - Left
FRT WASH PCB Relay
FRT WASH Fuse
HI BEAM PCB Relay
HI HEADLAMP - LT Fuse, HI HEADLAMP - RT Fuse
HORN PCB Relay
HORN Fuse
L/GATE PCB Relay
L/GATE RELSE Fuse
REAR WASH PCB Relay
REAR WASH Fuse
RUN PCB Relay
FWD Fuse, HTD STR/WHL Fuse
TRLR STOP LT PCB Relay
TRLR STOP LT Fuse
TRLR STOP RT PCB Relay
TRLR STOP RT Fuse
WIPER 1 PCB Relay
Wiper 2 PCB Relay
WIPER 2 PCB Relay
Windshield Wiper Motor
DRL PCB Relay
DRL Fuse
FAN CNTRL PCB Relay
Cooling Fan - Right
FAN HI PCB Relay
FAN LO PCB Relay
Cooling Fan - Left
FRT WASH PCB Relay
FRT WASH Fuse
HI BEAM PCB Relay
HORN PCB Relay
HORN Fuse
L/GATE PCB Relay
L/GATE RELSE Fuse
REAR WASH PCB Relay
REAR WASH Fuse
RUN PCB Relay
TRLR STOP LT Fuse
TRLR STOP RT Fuse
WIPER 1 PCB Relay
Wiper 2 PCB Relay
WIPER 2 PCB Relay
