2007 Suburban High Beams won't turn off
Old Apr 22, 2010 | 10:03 PM
dirtrider180's Avatar
Default 2007 Suburban High Beams won't turn off
About once every 2 weeks my high beams won't turn off when i turn off the headlights and the car. The only way to turn them off is to turn them on and off a bunch of times them they eventually turn off. Recently sometimes they also won't turn on. Only if I turn them on and off a few times do they finally come on. Sometimes if I turn them on they don't turn on right away but eventually turn on.
Old Apr 23, 2010 | 2:30 PM
Welcome to the forum.
Sounds like the stalk switch is/has going/gone Tango Uniform.
Old Jul 6, 2011 | 9:33 AM
pls2591's Avatar
what is the stalk switch and where is it located, i have the same problem with my 2007 suburban and the only way i can turn the hi beams off now is by removing the fuses
Old Jul 7, 2011 | 12:27 AM
The "stalk switch" is the turn signal lever. Pushing it forward turns the hi-beams on, pulling it back is for "flash to pass", a momentary all beams on. Make sure it's not in the forward hi beam position.
Old Jul 7, 2011 | 8:57 AM
The high beam relay might be sticking, check the under hood fuse block for the relay and swap with another or replace it, its an easy access place to start....
Old Jul 11, 2011 | 4:53 PM
pls2591's Avatar
in the under hood fuse block which one is the hi beam relay
Old Jul 11, 2011 | 7:21 PM
Ummm... well the manual says the hi beam headlamps relay is on a non-serviceable PCB....
Important: Relays listed below are non-serviceable Printed Circuit Board (PCB) relays and are internal to the block.
BCK/UP LAMP PCB Relay
VEH BCK/UP Fuse, TRLR BCK/UP Fuse
DRL PCB Relay
DRL Fuse
FAN CNTRL PCB Relay
Cooling Fan - Right
FAN HI PCB Relay
Cooling Fan - Right, FAN CNTRL Relay
FAN LO PCB Relay
Cooling Fan - Left
FRT WASH PCB Relay
FRT WASH Fuse
HI BEAM PCB Relay
HI HEADLAMP - LT Fuse, HI HEADLAMP - RT Fuse
HORN PCB Relay
HORN Fuse
L/GATE PCB Relay
L/GATE RELSE Fuse
REAR WASH PCB Relay
REAR WASH Fuse
RUN PCB Relay
FWD Fuse, HTD STR/WHL Fuse
TRLR STOP LT PCB Relay
TRLR STOP LT Fuse
TRLR STOP RT PCB Relay
TRLR STOP RT Fuse
WIPER 1 PCB Relay
Wiper 2 PCB Relay
WIPER 2 PCB Relay
Windshield Wiper Motor
Old Jul 11, 2011 | 11:33 PM
I'll bet if you can find the PCB and then find a suitable replacement relay, you can fix it.
Old Jul 12, 2011 | 7:36 AM
I believe it is on the bottom of the fuse block assembly, I'll investigate more this evening if I can and post more pics and info...
Old Dec 3, 2011 | 6:33 AM
aubiexx's Avatar
Did you figure this out? I have had the same problem for a year and after multiple trips to the dealer, just gave up and pulled the fuse.
