2007 Suburban LTZ no heat drivers side?
Old Dec 20, 2010 | 4:03 PM
RJK's Avatar
RJK
Default 2007 Suburban LTZ no heat drivers side?
When ever the heat is on it blows cold air on the drivers side but the passengers side works great providing heat. Any ideas why?
maybe Blend door actuator not working?
Thanks any input would be great. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old Dec 20, 2010 | 6:11 PM
Your guess is probably right since there has to be one for each side.
Old Dec 20, 2010 | 7:05 PM
something that might be worth reading over...
Service Information
2007 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 1710147
Actuator Recalibration
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
Place the ignition switch to the OFF position.
Disconnect the scan tool.
Install the HVAC control module.
Connect all previously disconnected components.
Start the vehicle.
Wait 40 seconds for the HVAC control module to self-calibrate.
Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:
Preferred Method (w/ Scan Tool)
Clear all DTCs.
Place the ignition switch in the OFF position.
Install the HVAC actuator.
Start the vehicle.
With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
Clear all DTCs.
Remove the HVAC/ECAS fuse for a minimum of 10 seconds.
Install the HVAC/ECAS fuse.
Start the vehicle.
© 2010 General Motors Corporation. All rights reserved.
pacemakertom
Dec 10, 2012 11:44 AM
jmarkv
Jan 24, 2012 8:21 PM
RJK
Jan 22, 2011 2:40 PM
clayman
Apr 19, 2009 7:55 PM
