2007 Suburban LTZ Spindles
Old Apr 29, 2013 | 8:55 AM
Chade7320's Avatar
Default 2007 Suburban LTZ Spindles
We just recently purchased an 07 LTZ Suburban. I noticed after driving it for a few days and seeing the other suburbans that ours sat much lower. I just chalked it up to it being two wheel drive. I finally decided to crawl under it and look. Sure enough it had been lowered.
With that being said. I have ordered OEM front spindles and OEM rear springs and plan to remove all the lowering parts this weekend. The rear is obviously pretty straight forward swap springs and put shocks back in stock location.
The front will need the spindles swapped from the lowering ones. Looking at it it looks pretty straight forward as well since its a 2wd. Having never done spindles on a vehicle is there any pointers or things that make it more difficult than it looks.
Old Apr 30, 2013 | 1:07 PM
country_09's Avatar
they're pretty straight forward...when tryin to "bust" the ball joints and tie rods out of the lowering spindles, use a rubber mallet and hit the side of the spindle, not the arms itself. And on the bottom of the ball joint, there is a spot for a L key to go in so you can loosen or tighten the joint up instead of stripping it out with channel locks or pliers
freyguy
Mar 10, 2008 2:03 PM
bub289
Nov 8, 2007 8:49 AM
einstein2nd
Sep 28, 2007 10:59 AM
ponykiller101
Jun 11, 2006 4:28 PM
