2007 Suburban shutting down
Old Nov 21, 2020 | 12:48 PM
Seanhackenberg's Avatar
Default 2007 Suburban shutting down
I have a 2007 Chevrolet Suburban LT, I love the vehicle but I’m running into a problem. I will be driving down the road and all of a sudden the Service Traction Control and the Service Stabilitrac will come on the dash and it will reduce the power of the engine or completely cut out. I replaced the Battery, Alternator, and the Crankshaft Positioning sensor but still having the issue. Anybody else run into this problem? If so what was the issue or can someone point me in another direction
Old Nov 21, 2020 | 2:30 PM
PNW NBS Z71's Avatar
Wheel speed sensors at the front wheels have been known to cause this problem. You may need to replace the front wheel hubs/sensors assemblies and make sure the wiring is all intact. The wiring that plugs in to the sensors sometimes gets mangled for some reason or another.
Old Nov 22, 2020 | 8:36 AM
repairman54's Avatar
Full spectrum code scan of all 4 code families is step one. Without that as a starting point it's just wasting money on parts and guess's.
Codes in the system will help point the way.
Just as a example the accelerator pedal position sensor will do that, common wear item, and can be erratic. It will go into reduced power mode when it acts up.
Get a full code scan.
Old Nov 22, 2020 | 10:10 AM
Yep, it is a drive by wire vehicle and that opens up other possible problem areas to look in to.
Mountaindahl
Nov 21, 2020 2:32 PM
Music Junkie
Oct 8, 2020 6:29 PM
thatguywill
Oct 14, 2014 11:15 AM
mluz
Oct 28, 2012 11:09 AM
Jerry Vaughn
May 14, 2011 4:19 PM
