CAM upgrade - computer - can it adjust?
Old Nov 22, 2020 | 11:22 PM
His Follower's Avatar
Default CAM upgrade - computer - can it adjust?
1998 K1500 Suburban 5.7L V8.
I've only really changed a few things. First was headers and cold air intake system. This was to help the Suburban tow better and I'm sure it made a difference,
Then I replaced the cam and lifters and rocker arms to get some more towing horsepower. It's all done but I'm not sure the performance is there. M\
My question is whether the computer can relearn and can it adjust to this CAM, or do I need to have the computer reprogrammed?Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,500-5,000
Intake Duration at 050 inch Lift:204
Exhaust Duration at 050 inch Lift:214
Duration at 050 inch Lift:204 int./214 exh.
Advertised Intake Duration:260
Advertised Exhaust Duration:270
Advertised Duration:260 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.429 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.452 in.
Valve Lift with Factory Rocker Arm Ratio:0.429 int./0.452 exh.
Lobe Separation (degrees):116
Computer-Controlled Compatible:Yes
Grind Number:2030
Dave19054
Aug 13, 2020 9:51 AM
Harley75
Jun 21, 2019 9:55 AM
gmycyk191
Apr 12, 2007 4:14 PM
