2007 Suburban - ticking/slight squeaking noise behind dash
Old Feb 12, 2012 | 8:19 PM
gamecock's Avatar
Default 2007 Suburban - ticking/slight squeaking noise behind dash
it kinda sounds like a cd spinning noise - but it is only when the heat/ac is on.....so obviously makes me think a fan belt squeaking.......but can't hear anything under the hood.
It may be the sound coming through the vents? Sounds like it is right behind the dvd/radio
any ideas?
Old Feb 13, 2012 | 9:08 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> gamecock,
I'm sorry to hear of the problem with your Suburban. It may be possible that something is obstructing one of the ducts. I offer this as a suggestion, not a diagnosis. I encourage you to take the vehicle in for an inspection. A certified technician should be able to offer a more accurate diagnosis after a physical inspection.
Please keep us up to date. If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
Old Feb 13, 2012 | 9:29 PM
jkj860's Avatar
any ideas?
If you have nav, try removing the nav disc and see if you still hear it. Mine was always accessing the disc and I always heard that sound although it didnt sound like a belt squeaking. Just a thought.
Old Apr 25, 2012 | 1:53 AM
wicg0317's Avatar
Default Jkj860
When you removed the nav DVD, did the noise stop? Did you reload it and then the issue resolve itself or did it continue? I am currently experiencing the same issue and any insight is appreciated.
My issue occurs when the vehicle is OFF. The DVD churns continuously like it is reading and loading.
Last edited by wicg0317; Apr 25, 2012 at 12:05 PM. Reason: Added clarification of when it happens.
Old Apr 25, 2012 | 11:04 AM
If it only makes the sound with the AC/Heat on then it could be the blower motor. The fan belts are always turning, it doesn't matter if the AC or heat are on or not.,
Old Sep 7, 2012 | 1:24 PM
FloridaTahoe's Avatar
Default Humming in Dash like a CD spinning or motor running
I just got my 2009 Tahoe and it does have the navigation and screen in the dash. Well whether or not my truck is running there is a noise coming from behind the navigation screen. I popped the disc out to see if that stopped the noise and it did not. I had to put a new battery in yesterday and I think this may be the cause of it draining. Went out there in the middle of the night and it was still making the noise!! Anyone experience this problem before and I was wondering what it could be so that I can get it fixed!! Thanks.
Old Sep 9, 2012 | 7:22 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> FloridaTahoe,
It is normal for the radio/navigation unit fan to run for up to three minutes after the vehicle has been turned off and the driver's door has opened or closed.
The disc spinning sound is also normal operation. After the remote keyless entry is used to unlock the vehicle or when the driver's door has been opened. The noise will also be heard during vehicle operation up to three minutes after the vehicle has been turned off and the driver's door has been opened and closed.
I regards to the battery issue, you may want to consider consulting with a certified technician if this issue persists. They will be able to offer additional information after inspection.
Please keep us posted.
If you have additional questions, please feel free to contact me privately.
Louis
GM Customer Service
Old Mar 16, 2014 | 12:47 AM
zig808's Avatar
Louis
GM Customer Service
Dear Louis,
Thanx for the informative post, i need some more tips from you related to the same topic of buzz sound behind the dashboard. You wrote previously that the sound of cd/nav unit is due to the fan on the unit, i need to verify it by disconneting the power of my cd/nav unit (suburban 2012). Please guide me how can i disconnect this unit in an easy and short way.
Thank you...
Old Mar 16, 2014 | 11:01 AM
They finally had to replace my head unit due to the fan never shutting down and it sounded like a bearing going out.
bigbillblood
Jun 10, 2014 8:23 PM
lspencer001
Aug 12, 2013 10:35 PM
MTopper
Dec 11, 2009 2:44 PM
bkj35
Oct 2, 2007 9:28 PM
gulfcoastjoe
Jun 23, 2007 8:48 PM
